I have a weird squealing noise in the rear(sounds like differential) during slow, tight turns. I assume this is the differential. Can this be caused by low diff fluid or something?
Originally posted by Spyfunkr I have a weird squealing noise in the rear(sounds like differential) during slow, tight turns. I assume this is the differential. Can this be caused by low diff fluid or something?
Thanks, Spy
Its caused by the break down of the fluid, the rear differential on the CRV's arent like other american cars they have clucth packs in them similar to whats in a trans. Honda usually recomend replacing the fluid at 60 k but i have seen the noise appear on lower mileage cars. Replace the diff fluid and us Honda Dual pump fluid and you should be fine.
Where the hell is the filling hole. I found the drain hole at the bottom, but nothing up top. I hope Im not supposed to use the drain hole to fill it?!?!?!?
