Change out Clock Bulb on Odyssey
pull the panel around you radio.pull the panel with the power sliding door switches(put the wheel to the bottom adjustment put on some gloves and get you fingers under the panels).Undo all the screws holding the clock panel on 2 are hidden upper side of the gauges.Pull the bulb little flat head.
