Minivan, SUV, & Truck RDX, Ridgeline, Element, Pilot, MDX, CRV, Passport, Odyssey, and SLX.
Jack Stand Placement
Old Oct 30, 2006 | 04:26 PM
odyowner's Avatar
odyowner
Default Jack Stand Placement
Looking to do a brake job on my '02 Ody. I can't find the best location to locate the jack stands. If I use the pinch welds ( where Honda suggests to lift the vehicle 4 places) then where do the jack stands go??? Not enough room to locate the jack stands and the floor jack at the same location even if the floor jack is moved slightly forward or back. Any advice????
Old Oct 30, 2006 | 05:39 PM
sleezye's Avatar
sleezye
ok u r going to do a brake job on your car but u catn figure out how to put the jackstands under it come on
Old Oct 30, 2006 | 06:10 PM
odyowner's Avatar
odyowner
Obivously you don't know where to put the jack stands either. The frame rails are considerly further up on the vehicle than most vehicles on the market. Especially at the rear end. So unless you have a permanent lift installed in your garage (which I do not) I am only asking how it can be done. no sarcastic replys please.
Old Oct 31, 2006 | 04:57 PM
Fuse's Avatar
Fuse
on the body seams 2 on each side look like ---I_____I----- on the seams thy are pushed out a bit if you need help on the brake job let me know i will help you for some reason
