timing belt
Usally a good ruel of thumb is 90k miles. The way i would check is look at the waterpump from behind the block. there is a little peice of it sticking out. If the aluminum is shinnier than the block then chances are the t-belt was replaced with it. Also look at the drive belts. They should say honda on them if they are original. But they still may have been changed but not the t-belt so thats not a solid sign
if you dont know when and if it was changed, get it changed, it costs a whole lot more to snap a belt and pay for a new motor then it does to just give u peace of mind!
To find out, you could check the service history and call the dealer who serviced it previously, Maybe they kept records of what was done!
