Minivan, SUV, & Truck RDX, Ridgeline, Element, Pilot, MDX, CRV, Passport, Odyssey, and SLX.
MDX Compression Test Results
Old Jan 17, 2005 | 08:07 PM
prelude97's Avatar
prelude97
Default MDX Compression Test Results
In the market for an Acura MDX 2001 41k miles. Compression is as follows
245, 232, 242, 225, 220, 230
max variation per spec is 28psi. These # show max variation as 245-220=25. Pretty close to the service limit. Also the # are just about 10% difference from min/max reading. I know that's a general limit for acceptability.
This was a leased car. Can someone "grade" these results, are these # more indicitive of an engine of much more wear? Dealer shows no oil changes, althought could have been done elsewhere. What do you guys think?
Thanks,
Jay
Old Jan 18, 2005 | 09:51 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
The numbers sound fine to me. There isn't much to worry about with an engine that relatively new. The result of a compression test can also change over the course of several tests.
