Minivan, SUV, & Truck RDX, Ridgeline, Element, Pilot, MDX, CRV, Passport, Odyssey, and SLX.
CRV Turbo???
Old Jun 23, 2004 | 07:19 PM
SHARKY2's Avatar
SHARKY2
Default CRV Turbo???
has anybody heard of a crv turbo???my friend is buying a '99 all wheel drive and he says he wants to turboed so he can trail his new boat???also wants to know how fast will it run in the 1/4 mile...also does any body sells a kit for it like "revhard" or would a kit for the ls teg woul fit???thanks any replies could send also to sharkylover2003@hotmail.com thanxs!!
Old Jun 24, 2004 | 06:26 AM
ED9man's Avatar
ED9man
driver
civic=not meant to tow
It doesn't matter if you increase the power, it's bad for the whole car.
Old Aug 3, 2004 | 05:22 PM
Knightmare69's Avatar
Knightmare69
Hater
I know I've seen ppl who run the CRV frankenstien engines with a turbo, you might want ask them where they got the kit. I think it's www.B20B.com or something like that. Good luck
Old Sep 2, 2004 | 02:34 PM
snoopyspaz's Avatar
snoopyspaz
I think there is a super charger kit out there but I could be wrong, hope that helps a little.
Peter
Old Sep 6, 2004 | 09:33 PM
turboprelude95's Avatar
turboprelude95
if you plan on boosting the b20 motor then don't push it more than 12 psi because the sleeves are weak and can crack but with very good tuning it can hold up for awhile.
Old Sep 20, 2004 | 06:04 PM
1jz gte_ jza70's Avatar
1jz gte_ jza70
rhd the only way to be!!!
It would not be hard to turbo it and run more boost then 12psi there is a company called dart that has a wonderful sleeving kit that will hold thru about 25psi. But I'm sure it would be much like tuning the franken motor swap he should look into a gsr head for better compression. With alittle time an money im sure he could run 12's or better. Best wishes
