Meets & Events Maximize efficiency in organizing local, regional, and national events.
Honda/Acura Challenge part 2.
Old Aug 7, 2003 | 05:26 PM
  #61
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Results are UP for the autocross side of Honda Fest 2003:
http://www.autox4u.com/2003results/832003hondaday.htm
NNJR SCCA - Event: 'Honda Day 2' 08022003
- Final Results
Results from: 'HDAY.REG' Total entrants 43
* 1 BS 223 John Bogard
48.722+9 38.348+9 38.110+9 36.838+9
36.608+6 36.584 36.363+1 > 35.847 T: 35.847
* 2 BS 32 Gerald Trazilla
62.568+9 41.001+9 39.095+9 37.408+9
> 36.619 36.874 37.003+2 37.389+1 T: 36.619
3 BS 224 Sander Marques
44.259+9 38.624+9 37.797+9 38.341+9
38.221 37.840 > 37.183 37.654 T: 37.183
4 BS 34 James Giannone
> 43.724 39.654+9 T: 43.724
5 BS 336 Jose Nieves
41.368+9 > 38.835+9 T: 56.835
* 1 CS 24 Gill Bucher
36.528+9 34.803+9 34.323 34.166+1
33.968 > 33.669 T: 33.669
* 2 CS 42 David Mc Dougall
34.789+9 34.115+9 33.890+1 > 33.948
33.669+1 33.458+2 T: 33.948
3 CS 72 Ryan Chan
38.279+9 36.145+9 37.857+9 36.304+9
> 36.249 35.787+2 36.910+1 36.251 T: 36.249
4 CS 17 Mike Wong
39.805+9 40.049+9 37.234+9 35.798+9
36.873 35.771+3 35.969+1 > 36.530 T: 36.530
5 CS 88 Andrew Gritsanenko
43.977+9 45.480+9 42.694+9 42.222+9
42.497 41.687 40.728 > 39.495 T: 39.495
* 1 DS 18 Ken Kong
38.168+9 36.530+9 35.322+9 35.152+9
34.686 34.900 34.773 > 34.098 T: 34.098
2 DS 6 Josh Nolan
44.940+9 41.249+9 40.882+9 39.569+DNF
39.139 38.362 > 37.803 38.024 T: 37.803
3 DS 214 Alex Siedlecki
46.629+DNF 42.283+DNF 42.724+9 40.751+9
40.321+2 > 39.581 38.525+2 37.939+DNF T: DNF
* 1 ES 319 Tony Passalaqua
37.043+9 35.017+9 34.940+9 35.204+9
34.656 35.183 > 34.228 35.008 T: 34.228
* 2 ES 166 Dan ***
37.355+9 36.713+9 37.314+9 36.061+9
47.155 > 35.497 35.909 36.263+3 T: 35.497
* 3 ES 78 Alexander Nicolas
42.196+9 40.893+9 39.940+9 39.329+9
38.411 42.416+1 > 37.710 37.718 T: 37.710
* 4 ES 5 Dan Roman
45.288+9 53.438+9 46.347+DNF 39.326+DNF
38.591+DNF 37.982+DNF 37.865+DNF > 38.463 T: 38.463
5 ES 827 Chris Spadaro
52.853+DNF 41.868+DNF 44.804+9 40.999+9
39.672 39.962 > 38.926 38.998 T: 38.926
6 ES 15 Ken Martinez
52.134+DNF 43.658+DNF 41.506+9 40.731+9
40.395 39.657 > 39.168 39.358 T: 39.168
7 ES 28 Enrico Patricio
45.393+9 41.261+9 41.429+9 41.251+9
40.912 > 40.014 45.305+2 40.951 T: 40.014
8 ES 33 Jan Dittmar
44.141+9 42.034+9 42.000+DNF 40.679+DNF
39.402+DNF 38.777+DNF 39.400+3 > 40.546+1 T: 42.546
9 ES 223 Dustin Bauley
> 45.297 T: 45.297
10 ES 222 Mike Davis
43.461+9 > 38.840+9 T: 56.840
* 1 FS 337 Javad Muhammed
43.218+9 43.775+9 44.131+9 41.411+9
40.962 40.921 41.011 > 39.573 T: 39.573
* 2 FS 48 Jake Silverio
47.747+9 42.163+9 42.811+9 41.496+9
> 39.604 40.044 40.321 39.976 T: 39.604
3 FS 26 Jim Cordenas
55.653+DNF 46.412+9 40.503+9 42.683+9
42.023 41.581 > 40.455 41.258 T: 40.455
4 FS 811 Muhummad Rahman
55.366+9 45.396+DNF 46.063 43.508+9
43.886 41.847 42.695 > 41.720 T: 41.720
5 FS 225 Brad Cherone
50.936+9 45.562+9 44.057+9 43.211+9
> 42.610 T: 42.610
6 FS 35 Glascow Tennizle
57.688+9 52.062+DNF 49.765+9 49.281+9
46.708 45.460 44.286 > 43.665 T: 43.665
* 1 SM 204 Kevin Lau
34.490+9 33.380+9 > 32.733 32.595+1 T: 32.733
* 2 SM 56 Mike Ancas
37.264+9 34.371+9 33.149+1 33.640+1
> 32.976 T: 32.976
* 3 SM 815 Raymond Yue
38.964+9 34.244+9 34.037+1 33.899
> 33.301 T: 33.301
* 4 SM 814 Anthony Crea
34.477+1 34.307 > 34.092
34.078+1 T: 34.092
* 5 SM 803 Michael Louie
48.943+9 35.194+9 35.512 > 34.100
34.712+2 T: 34.100
6 SM 812 Drew Banghart
41.681 37.357+9 35.887 35.818
> 34.612 T: 34.612
7 SM 211 Edwin Vanegas
38.189+9 36.688+1 > 36.798
35.921+1 T: 36.798
8 SM 136 Jon Andes
40.642+9 40.082+DNF 38.939 38.193
> 37.784 T: 37.784
9 SM 483 Thomas Capasso
43.461+9 33.583+9 > 37.947 37.538+1
36.817+3 T: 37.947
10 SM 694 Ben Rivera
45.628+9 44.349+9 40.074 39.978
> 38.100 T: 38.100
11 SM 212 Tina Chen
52.084+9 37.634+9 43.435 44.213+1
> 43.096 T: 43.096
12 SM 214 Alex Siedlecki
-dns- T: DNS
13 SM 222 Mike Davis
-dns- T: DNS
14 SM 827 Chris Snadaro
-dns- T: DNS
Top Time of Day - SM 204 Kevin Lau
Run 3 - 32.733
Autocross Help Page
Old Aug 7, 2003 | 05:32 PM
  #62
sts2poc1's Avatar
sts2poc1
20-30 runs man thats cool but to bad I'm in CO, or else i would be there to auto-x
Old Aug 7, 2003 | 06:58 PM
  #63
CivicSiRacer
Originally posted by FromTheBottom
I was running about 27-29 psi all around (crappy tire gauge)...stock tires call for 30F/29R. The chalk lines very totally worn off, so I had a lot of lateral rollover. I don't think it's so much the tire pressures, but the fact I'm running on pretty beat up tires. Tread is okay on them, but their overall condition is very poor, so just based on that, they tend to give too easily.
I'm looking into new rims in a month or two, once I can afford them. I know you're running on K1's which are 15x7. Is there much difference over 15x6.5 Rotas (C8, C10 or Slips) or Konig (Heliums)? I'll be giving the Azenis a try also.
Aug 29th sounds good!
Thanks.
That's way too low! I'm running stiff sidewall tires and run 40f/47r. For street tires you need at least 45psi front and 40 psi rear.
Autocross Help Page
Old Aug 7, 2003 | 07:13 PM
  #64
FromTheBottom's Avatar
FromTheBottom
Driver of Trains
my tires call for 30F/29R...is it safe to put them up around 45?
also, please let me know what you think about the 6.5" vs. 7" width in 15" rims from my last post. thanks mike.
Old Aug 7, 2003 | 08:35 PM
  #65
CivicSiRacer
Yes it's safe. You can put more pressure in tires AS Long as you do not drive on them for long periods of time. Like my tires have a limit of 51psi but I put 60psi in them on Saturday for the drags.
And as for 6.5" vs 7" wider is always better but you need a tire that will work on a 7" vs a 6.5". 205 is great for 7" OR 6.5" but will sit better on a 7" wheel. As far as difference in feel you will prolly never notice a difference. As you get faster and better maybe that .5" you will feel. I'm thinking of trying the 15x6.5" Heliums myself since I can get them dirt cheap from my sponsors
Autocross Help Page
Old Aug 9, 2003 | 11:22 AM
  #66
CivicSiRacer
Videos are up (I only have one more to go - thank goodness for 56K!)
http://www.imagestation.com/album/?id=4289458139
Autocross Help Page
Old Aug 9, 2003 | 12:01 PM
  #67
Jessica's Avatar
Jessica
ch1x0r
Old Aug 9, 2003 | 06:50 PM
  #68
CivicSiRacer
I also found out why I was running so CRAPPY at Honda Fest. One of my spark plug wires was either pulled off (by someone else) or it shook itself loose - which I would think is hard to do. I'm hoping someone wasn't trying to be a cheaper and pull my spark plug wire off my distributor. My fastest time was a 16.3, which with my mods I should have at least been in the 15s.
AND there was also a crack on my my header right by the hanger.
Autocross Help Page
Old Aug 9, 2003 | 07:51 PM
  #69
FromTheBottom
Driver of Trains
thanks for the vids mike!
and yeah...a loose spark plug wire must've been my problem too!
either that or the fact that i was a autocross virgin and apparently i got the tire pressure theory ALL wrong.
i'm trying to make it down to giants stadium on the 29th. with proper tire pressure this time
Old Aug 9, 2003 | 08:02 PM
  #70
CivicSiRacer
I have the go ahead to go to the 29th at Giant's stadium See ya there. MIght go to the 16th autocross at Englisntown too.
Autocross Help Page
