92 Acura Legend
Old Aug 22, 2008 | 08:18 PM
dnice63's Avatar
dnice63
Default 92 Acura Legend
I have a 92 Legend Coupe, I can start the car let it run for a while the cut it of it will not start back up. Sometimes for a couple of hours sometimes for a couple of days. I have try changing the main relay(new), the crank sensor(new), starter(new), even check the cam shaft sensor. I am still having the same problem. Any help? Thank You.
Also does anyone no where the diagnostic hook-up is in this car or is there on on this model?
Old Aug 23, 2008 | 04:48 AM
L3GKANG's Avatar
L3GKANG
Prezz of ACURA-HOLIKS
do get a check engine light? if so you can run the codes with a chilton book but i try to get the big gray book off ebay its from the dealership but you cant buy it.
Old Jan 18, 2009 | 11:29 AM
red legend's Avatar
red legend
i think it is from the fuel pump
