P1259 on 2001 Insight
Old Sep 11, 2005 | 06:50 PM
Rory_W's Avatar
Rory_W
Default P1259 on 2001 Insight
While driving my car engine started to die and then the check engine light came on. Car started to drive fine, but when checked to see trouble codes, I had a P1259 VTEC code malfunction. I'm assuming P1259 is a VTEC code on the Insight. My freeze frame data is as follows.
Fuel Sys1: Open Loop Driving
Calculated Load: 50%
Coolant Temp: 197.6 deg F
Short Term FT,B1:0.0%
Long Term FT,B1: 0.0%
Manifold Absolute Pressure: 14.8inHg
Engine RPM: 4625RPM
Speed: 53.1MPH
Intake Air Temp: 116.6Deg F
Throttle Position: 24.3%
Any help will be appreciated.
