Clutch fluid
Old Jul 16, 2002 | 03:14 PM
Weston's Avatar
Weston
Default Clutch fluid
Clutch fluid is the same as brake fluid, right? Can I just go get some at AutoZone, or is it bad to mix different kinds? Thanks
Old Jul 16, 2002 | 03:24 PM
newgsrdriver's Avatar
newgsrdriver
The clutch fluid that you put in your reservoir is DOT 3 or 4 brake fluid...same stuff.
Autozone stuff is fine.
Old Jul 16, 2002 | 05:26 PM
Weston's Avatar
Weston
I just looked at the fluid and it looks full, but I can see crap in it. So, I'm going to flush the fluid tomorrow morning...
Anyone know the correct way to flush the clutch fluid? Should I just get like a turkey baster thing and suck all the old stuff out, then refill it? Anything else I need to do?
Old Jul 16, 2002 | 08:00 PM
abe's Avatar
abe
SLOW DOWN!!!
oh, boy....you're looking for trouble, if that's what you plan to do. have a shop do it for you instead.
Old Jul 16, 2002 | 08:04 PM
dubcac's Avatar
dubcac
I
:werd: Turkey baster is not the way to bleed the clutch system.
Old Jul 16, 2002 | 10:01 PM
Weston's Avatar
Weston
:rofl: I didn't know there was a way to bleed it... I just heard of someone using a turkey baster before, but I was wondering how the hell you get the stuff at the bottom. Where's the bleeder valve for the clutch fluid?
Old Jul 16, 2002 | 11:01 PM
abe's Avatar
abe
SLOW DOWN!!!
[BWhere's the bleeder valve for the clutch fluid? [/B]
slave cylinder
Old Jul 17, 2002 | 11:42 AM
AP2's Avatar
AP2
Moderator Alumni
Slave cylinder that's located near where the block/tranny bolt up, between the radiator and block. Look for that little screw.
Old Jul 17, 2002 | 12:58 PM
Daniel's Avatar
Daniel
1) Remove clutch master cylinder reservoir lid.
2) Locate bleeder valve on slave cylinder (right below engine stamp, to the left of header), remove rubber cap (if equipped).
3) Loosen bleeder valve, have friend begin pumping clutch.
Friend must also make sure reservoir never loses fluid, he must continue to fill with appropriate brake fluid
4) Once you've identified that there are no more air bubbles coming out, close bleeder valve screw, replace rubber cap.
5) Fill clutch master cylinder reservoir to max level, replace reservoir lid.
That should take care of it!
Old Jul 17, 2002 | 01:34 PM
Weston's Avatar
Weston
Cool, thanks. I guess I'll have to sucker someone into helping me this weekend...
Is the fluid coming out of the bleeder easy to collect in a bottle or something? Or should I do this somewhere that I can make a mess?
