am i just paranoid....
Old Sep 12, 2003 | 12:17 PM
TarHeeL-Si's Avatar
TarHeeL-Si
Default am i just paranoid....
my clutch squeeks a little when i have my car at a stop and i let it in and out...other than that it doesn't squeek. and it feels like its getting "looser' thats teh best i can explain. like when i downshift it doesn't seem like it grabs as quick, also it sort of feels like i can start from a stop without using as much clutch....am i just paranoid or do i need to get it checked?
kellen
Old Sep 12, 2003 | 12:25 PM
Daniel's Avatar
Daniel
The squeeking is a typical Integra problem. Our clutch master cylinders usually go out. Poke your head up in your footwell and see if you see any brake fluid sliding down the firewall from where the clutch master cylindre is.
Old Sep 13, 2003 | 01:07 PM
DVPGSR's Avatar
DVPGSR
I need sleep...
After I read this yesterday mine started squeaking. I checked for any leaks and there were none...when I took it out last night to go to Slacker's house the squeaking was gone. Could be nothing...who knows?
Old Sep 13, 2003 | 01:13 PM
Shore 96 Teg's Avatar
Shore 96 Teg
I miss my 93 VTEC Lude :(
the squeaking thingsisnt just an Integra problem. My clutch squeaked on my Si Prelude. I had it for 3 years liek that and i had no problems. You may just needto replace the clutch soon,
Old Dec 23, 2003 | 05:53 PM
95lsintegra's Avatar
95lsintegra
my 95 integra does that but it happens almost every time i shift into 1st, 2nd, and 3rd. i was told its becuase of my sprung clutch disc.
Old Dec 23, 2003 | 06:46 PM
DVPGSR's Avatar
DVPGSR
I need sleep...
Damn...another post back from the dead. Thanks noob:fawk:
But hey you used the search button....props to you :thumbup:
Oh and my clutch still squeaks avery now and then.
Old Dec 26, 2003 | 12:08 AM
Takumi Fujiwara's Avatar
Takumi Fujiwara
Mine doesn't squeak. It used to "click" from time to time, but after I switched out the CMC, I haven't even had the clicking.
Old Dec 26, 2003 | 08:41 PM
silver_teg007's Avatar
silver_teg007
Mr.
Default Re: am i just paranoid....
kellen
my clutch squeeked too. I checked everything out and I guess there was nothing wrong because it stopped by itself after a while...Check your clutch master cylinder, and check for leaks.
If your clutch isnt "grabbing" into gear as well as it did before, thats an entire different issue...
good luck
-Sean
Old Dec 27, 2003 | 12:03 AM
TarHeeL-Si's Avatar
TarHeeL-Si
wow...this post is old ass...my clutch just randomly squeeks still but its not a big problem at all. everything is working fine, i did hear about some oil or something..im thinking teflon, that you can put on it that might help...anyone know what to use
