stock alternator amperage output?
Old Sep 2, 2003 | 10:18 AM
vtecn00b's Avatar
vtecn00b
Default stock alternator amperage output?
on a 98 GS-R
I found 90A in a post in the electronic forum... but I need a confirmation... I couldn't find anything on google... only after market specs :/
An article at Crutchfield says that most honda alternator only out put 35A. I'll be running a 520 RMS system... which is about 37A... is that right?
Old Sep 3, 2003 | 12:37 AM
Spec R's Avatar
Spec R
Hmmm thats a good question, but i'll tell you this...
I'm running a 460x1 watts RMS for my sub, as well as a 50x4 watts RMS for the interior, so I guess thats 660 RMS worth of power...
I'm running off the stock alternator fine, although I'm using 4 gauge power AND ground cables. I have a distribution block in the trunk that splits the 4 gauge power cable coming from the battery to 8 ga wires to the amps.
A couple months after the initial install, I used whatever excess 4 gauge wire to make new ground wires for the battery and valve cover. This made a suprisingly big difference in bass richness, fullness, and overall sound. My headlights dimmed less when I pushed up the volume.
Its been a little under a year since I did the first stage of the install (amp and sub), and i've never experienced a battery failure.
DB Squad
Integra Forum Moderator
Old Sep 3, 2003 | 03:34 PM
st0ckWhee1s's Avatar
st0ckWhee1s
It's a 90 Amp. I'm running 1600 watts RMS through 0 guage wire with two 1.2 farad caps. My car's fine. You should have no problems.
