that gas smell, thats good right?
Old Jul 13, 2002 | 08:05 PM
acuraocd's Avatar
acuraocd
Default that gas smell, thats good right?
ok first off if i were to start my car and let it idle, and mvoe the steering wheel a llittle...... my rpm's drop down to almost 0 and then it jumps back up and bounces around..........
second- i am getting a gas smell inside and out........ ECU code is 43 Fuel Supply System any ideas......... O2 sensor, distributor heeeeelllllpppppp thanks
Pictures at Cardomain.com
http://www.cardomain.com/member_page...cura%20Integra
Old Jul 13, 2002 | 08:46 PM
Snoopy's Avatar
Snoopy
been there done that
if you can smell gas from inside, thats a bad thing. might wanna check your fuel lines first. since your ECU code is Fuel Supply System that could be it.
Old Jul 13, 2002 | 08:54 PM
pomansouth's Avatar
pomansouth
umm sounds like what the first guy said but to check you might wanna look under your car to see if there is gas on the ground and if so then find the leak and replace the line or maby even patch it
Old Jul 14, 2002 | 11:53 AM
TheBlazer's Avatar
TheBlazer
It shouldnt come close to stalling when turning the steering wheel. How many miles you got on it?
Old Jul 14, 2002 | 05:19 PM
slickboy's Avatar
slickboy
ECHC junkee
You should definately check your injector seals. There has been more than one Honda in my family that those have worn out on. The outsides of the injectors may be slightly discolored, or if the injector itself looks wet at all.This can be noticed if you run your A/C system on fresh instead of recirculate. These seals just wear out over time. Just my $.02.
Old Jul 14, 2002 | 05:46 PM
G2Integrity's Avatar
G2Integrity
Sounds like my car before I got it all tuned. Do you have aftermarket cams?
No, it is NOT good. Your car is struggling to idle. Get it fixed.
Old Jul 14, 2002 | 06:24 PM
acuraocd's Avatar
acuraocd
fixed my problem there were 2 vacume hoses that melted in the fuel injetor and i taped em up and the car ran fine.......... i just got the motor in like a month ago it only has 20k on it i was gettin pissed and worried........ thanks for the tips for all you that like to fix cars on your own get the Haynes re-pair manual............
Old Jul 15, 2002 | 07:09 PM
rtzx9r's Avatar
rtzx9r
sounds to me like a lack of fuel pressure. When you turn the wheel, a load is placed on the engine requiring more gas. (load from power steering pump) You probably have a leak in the fuel system somehwere, and that is what is causing both the drop in rpm and smell. Does the car accelerate like it usually does as well?
Just Janna
May 31, 2007 01:23 AM
sinthetiq
Mar 31, 2004 08:34 AM
93DelSolSi
92+ Civic/EL & Del Sol
11
Mar 30, 2004 06:49 PM
BullFrogger
Mar 19, 2004 07:50 AM
