itrt
Old Jul 28, 2003 | 10:00 AM
00R101's Avatar
00R101
Originally posted by Digit
can someone whos really an expert on this explain it to me or point me to a source, honestly i dont know anywhere near as much as you do about this
i just know that there are people that turbocharge itrs and some that take your side, id just like to know....well, basically everything about it
This is not that tough. All forced induction does is raise the pressure in the cylinder by forcing more air and fuel in. The more air and fuel you have in the cylinder the bigger the bang, the more power.
The problem is that if you put fuel and air under pressure then the temperature at which they explode gets lower. Too much pressure or too much air and fuel and the explosion happens before the sparkplug fires and while the piston is still moving up the cylinder. This is called preignition or pinging. It is very bad. When it happens many things could go wrong. You will lose power; you might snap a connecting rod; blow out a ring or a seal; crack the block; etc, etc ,etc.
So when you turbocharge or supercharge an engine you must limit boost pressure so that the amount of pressure plus the engine's compression ratio does not lead to preignition.
The problem with turbo or supercharging the ITR is that the ITR already has a high compression ratio. So you must keep the boost pressure pretty low to avoid preignition. So the gains in HP and Torque that you will get are not nearly what you would get form a lower compression motor (like the GSR or RS or LS).
To make an ITR a good candidate for forced induction would require making the motor stronger (rods bearings gaskets ) and/or putting in lower compression pistons.
So, you could put FI on an ITR motor but it would not give nearly as good bang for the buck as putting FI on an LS motor. Most ITR lovers think its a waste of a carefully engineered motor to "spoil" it in this way.
Regards,
Alan
Old Aug 7, 2003 | 01:11 PM
Capt. Type R's Avatar
Capt. Type R
well, there you go. put very nicely and simply. nice explaination.
Old Aug 7, 2003 | 02:00 PM
TypeR0928's Avatar
TypeR0928
Money!
If you got it then you can boost the **** out of any car. Everyone has their own opinions.
Old Aug 7, 2003 | 03:29 PM
Shingoblade-GSR's Avatar
Shingoblade-GSR
Hellsing Agency
Default Re: itrt
i heard stock itr have trouble handling turbos, what needs to be done for the motor to safely handle being turboed
Build the motor the same way as you would a turboed B18C1. There's actually a few technical threads regarding this route (on the "lesser" GSR) if you do a quick search.
Shingo
Old Aug 8, 2003 | 01:10 AM
Spec R's Avatar
Spec R
i had a friend that had a jdm ITR motor in his EG, and he turbo'd it cuz he was sponsored a DRAG gen 4 kit for 1000 bucks (it was one hell of a show AND go car). lets put it this way, he went back to NA after 3 months of not being able to push it hard.
DB Squad
Integra Forum Moderator
Old Aug 24, 2003 | 10:40 PM
FocuzDave's Avatar
FocuzDave
Member with a mega dong
Does anyone know the times comparing boosted itr/gsr engines?
Old Aug 27, 2003 | 10:08 AM
ISS Elite R's Avatar
ISS Elite R
New Image PIMP
NA all the way.
Old Aug 30, 2003 | 03:52 PM
Capt. Type R
i agree..NA all the way. especially on a type R engine.
Old Aug 30, 2003 | 10:24 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
Times will probably be about the same. The itr might make a little more power because of the higher compression. Also the lsd will help it run faster.
Old Sep 3, 2003 | 06:55 PM
Import-Tooner's Avatar
Import-Tooner
skoooooie!
LSD is oh so sweet.
+Chanc+ says: I went pee with gloves on.
SKOOIE!!!
