Need Help installing Springs
Old Jul 14, 2003 | 06:42 PM
Skelly_GSR's Avatar
Skelly_GSR
RB does men
95 teggy...you can do it!! trust me. Drop me a pm and I will give you my phone number with every direction you need!
Old Jul 14, 2003 | 06:49 PM
b00gers's Avatar
b00gers
Originally posted by 95TEGGY
thanks man, does anyone know how much it will cost if i take it into the shop?
$120...give or take $20. i figure someone at a shop can do it in less than 2 hours.
Old Jul 14, 2003 | 06:52 PM
Skelly_GSR's Avatar
Skelly_GSR
RB does men
In my local area, they all quoted me about 300ish.
Old Jul 14, 2003 | 06:53 PM
DVPGSR's Avatar
DVPGSR
I need sleep...
$250 here...ended up doing it myself for $65
Old Jul 14, 2003 | 07:50 PM
WhiteLitening's Avatar
WhiteLitening
I'm like dis'........
it is very easy, all i would suggest you do is go to a shop to get your rear shock bolts loosened like mentioned earlier. if you don't, most likely you will break them like almost everyone else does including myself. then after you break them, its a pain in the ass!! good luck
Old Jul 14, 2003 | 11:30 PM
95TEGGY's Avatar
95TEGGY
so what do u do after you break em, do u have to buy new ones or what?
Old Jul 14, 2003 | 11:31 PM
95TEGGY's Avatar
95TEGGY
also do u guys know if like midas or shops like that will do the suspension or do i have to take it to like a suspension shop or something? Thanks
Old Jul 15, 2003 | 04:50 AM
Skelly_GSR's Avatar
Skelly_GSR
RB does men
Ok teggy, heres what they mean by getting the bolts "broken". The ones on the lca(lower control arm) are usually frozen like you woldent believe. So its the best and easiest to run down to midas and give them 20 bucks to break them loose. So when you get home they can come out easily.
Old Jul 15, 2003 | 09:52 AM
b00gers's Avatar
b00gers
the head usually breaks off. then you are stuck with drilling them out. PITA.
you can also try to soak it in some penatrating oil.
Old Jul 15, 2003 | 10:22 PM
WhiteLitening
what we are all trying to tell you is go to a shop, have them break the bolts free, that way you don't have to spend the money on the two new bolts, and you don't have to endure all the frustration and lost time from breaking them. the money you would have spent on the bolts can be saved and used to pay the shop to break them free for you. so either way, its gonna cost you a few $, but nothing major and you save A LOT of time by doing it this way.
