how long is a b-series shift linkage?
just how many feet or inches is a b-series shift linkage. Just the part that holds the shifter. Not the part that connects to the shifter. And another thing, does someone have a pic so i can see where it goes? In other words where does it bolts up too??
so are you talking about the "support" for lack of better terms, it bolts up with one 10mm(head) bolt to the side of the tranny beside linkage and around the shifter ball just below floor board and above linkage bolt, the linkage bolts to bottom of shifter and to shift pin in tranny, and is aprox. 2-3' long, hope that helps
I got under another integra and measured 45.25 to 45.5 inches. and yes its the above shift linkage that bolts to the side of the tranny and 2 10mm bolts holds this one up right next to the shifter.
