Gear lube in differential
Old Jul 7, 2003 | 08:02 PM
stevieteg's Avatar
stevieteg
Default Gear lube in differential
When I replace my clutch recently some vary thick gease/oil came out of my differential. Is that normal? I thought just mtfluid went in there. Was the last owner of my motor an idiot, or am I missing something? btw no oil came out of the differential when I pulled the axles, just the thick oil when I tipped the transmission on it's side.
Old Jul 11, 2003 | 07:53 PM
MikeR's Avatar
MikeR
manual tranny calls for motor oil doesn't it, 30 weight i thought
Old Jul 12, 2003 | 03:30 PM
Tobra's Avatar
Tobra
No, this will trash your synchros. Use Honda fluid, or Redline MTL< royal purple, etc etc. Perhaps it was some old, sludge a nd crapola from poor past maint.
Old Jul 12, 2003 | 04:20 PM
LT's Avatar
LT
The deer had to die!
did you replace it yourself?
Old Jul 16, 2003 | 06:35 PM
MikeR's Avatar
MikeR
i thought so....check it out: http://www.hazone.com/hbtrannyoil.htm
Old Jul 17, 2003 | 02:00 PM
stevieteg's Avatar
stevieteg
Heres what happened...
I bought a rolled over gsr to use the motor in my ls. When I took out the gsr motor no oil came out when the axles were removed. I thought, oh great who knows how long this has been this way. When I replaced the clutch, the transmission was sitting on its side and all of this very thick oil came out. It looked like gear lube from the lower unit of a boat motor. When I bought the gsr it was driviable, but very hard to get into first gear. Now that the swap is in my ls, I put honda mtf in the gsr tranmission and everything works great. Who knows what was actually in my transmission.
