springs
Old Jul 7, 2003 | 06:17 PM
Hondavirgin's Avatar
Hondavirgin
Default springs
hey, i'm looking to do the suspension on my integra (GS-R over in the US).
I've been told by a fairly reputable source that I don't absolutely need springs changed if i get Koni externally adjustables and a rear sway bar, as apparently the honda's springs are pretty ok to match them already, and if i were to go the springs as well the car coiuld get skittish on rough roads around corners.....
the springs will drop the car about 1.5 inches, any scraping problems with this drop?
Old Jul 7, 2003 | 06:32 PM
Clean00GSR's Avatar
Clean00GSR
B18c1 >*
:ugh:
Old Jul 7, 2003 | 07:06 PM
BonzoAPD's Avatar
BonzoAPD
Default Re: springs
what springs are you talking about?
Old Jul 7, 2003 | 07:42 PM
Hondavirgin
These are a brand called whiteline, don't know if they export.
Old Jul 7, 2003 | 08:10 PM
b00gers's Avatar
b00gers
what is your goal in the end? better handling car? lowered ride height?
Old Jul 7, 2003 | 08:14 PM
Hondavirgin
my goal is better handling, but a lowered ride height would be good too.
Main thing is the handling though. it just seemed strange that the honda springs could handle much harder shocks without problems, i would think that Honda would have got the springs spot on for the car's OEM shocks when they designed the thing.
Old Jul 7, 2003 | 09:05 PM
b00gers's Avatar
b00gers
you may want to ask the autox forum these questions also.
heres my take on it:
you want to better handle your car, learn your car. take some classes on how to drive. got that from rick.
your tires is the only part of the suspen that makes contact with the ground, best to upgrade those.
"upgrade" to springs with a stiffer spring rate, and with that, also shocks that can keep up with the rebounds.
Old Jul 7, 2003 | 09:12 PM
Hondavirgin
yeah, i am taking those classes, as for tyres, i know they need upgrading too, got Bridgestone Potenza on it atm coz thats what it had on when i got it, but i know they need upgrading, but they're not overly expensive.
thats what i thought about the springs, but this guy thinks that the OEM springs will match the shocks.
Old Jul 8, 2003 | 07:57 AM
teg_fan's Avatar
teg_fan
I like integra's
I'd say go with aftermarkey springs unless you can't afford them right now and you must put your shocks on right away. It's easier to do it all at once though in case down the road you realize that you should have gotten springs also.
Old Jul 8, 2003 | 02:05 PM
95TEGGY's Avatar
95TEGGY
hey i gotta question, do you think if i put eibach srpings on my integra rs with stock shocks it will work or will they totally mess up my shocks? Thanks for input
