Power Window Problem
Old Jun 26, 2003 | 01:56 PM
SupaDave's Avatar
SupaDave
Default Power Window Problem
Hey Peeps
I have a 96 teg sedan. My back passenger window will not go down. The window will not response if I use the master switch (driver's switch) or that window's switch. Also, there is no humming noise from the motor when I hit those switches. I was wondering is it safe to assume that the problem is with the motor and not the switches. All other windows work fine. I priced a motor at a junk yard and they want $65 for the motor and $55 to put it in. I don't mind paying for it if it's the right problem, any suggestions? Thanks
Old Jun 26, 2003 | 02:34 PM
90'RS's Avatar
90'RS
before spending the money like that even though you don't care about it try and test the switches to see if they work properly. All you need is a volt meter.
