Need Help Quick Please...
Old Jun 25, 2003 | 12:40 PM
HYBRID's Avatar
HYBRID
Default Need Help Quick Please...
i have the chance to buy some nsx calipers front and rear, will they fit onto my ls or do they only fit type-r's? if anyone knows please help me out. thanks.
Old Jun 25, 2003 | 12:48 PM
DVPGSR's Avatar
DVPGSR
I need sleep...
I think they are too big...I could be wrong though.
Old Jun 25, 2003 | 12:51 PM
airon's Avatar
airon
AARONNOJIMA.COM
ive only seen them fit on ITR's, but i could be wrong
you should see about getting some ITR calipers and havings some custom rotors made for them
Old Jun 25, 2003 | 01:23 PM
Spec R's Avatar
Spec R
ditto
DB Squad
Integra Forum Moderator
Old Jun 25, 2003 | 02:14 PM
Daniel's Avatar
Daniel
It's possible to install NSX rotors on GSR hubs, but you will have to do some work. Calipers with brackets and bolts, 11in rotors redrilled to 4 x 100 and appropriate pads. Also, it seems there's some metal that will need to be filed down for clearance.
I've got a local guy in Charlotte that upgraded his ITR to Acura Legend rotors and calipers. These are the same as NSX, but can be found for cheaper. I don't have all the tech information to do this swap, so I'd say keep researching, but it is possible.
Old Jun 26, 2003 | 11:00 AM
HYBRID's Avatar
HYBRID
how if you do a 4x114.3 earlier type-r conversion the calipers can fit right? what kind of modifications need to be done to fit the calipers even if installing on the usdm 5 lug type r?
Old Jun 26, 2003 | 11:32 AM
Daniel's Avatar
Daniel
Go with the Acura Legend calipers and rotors from 94-95 GS (sedan) or 93-95 (coupe) for best fitment. No additional modifications required except for a couple of washers to shim the caliper for the best fitment of the bolts. Cost would be from $100-$350 depending of if you buy new or used.
Email this guy mikeymike1979@hotmail.com who's done the swap already. He's an excellent source for information regarding this modification.
Old Jun 26, 2003 | 06:27 PM
HYBRID's Avatar
HYBRID
thanks drumsy, so the Legend caliper is the same as the NSX caliper (2 piston?) ? and if i were to want to use the NSX caliper would it still work the same as using the Legend one? thanks for everything
Old Jun 27, 2003 | 04:26 AM
Daniel's Avatar
Daniel
The only differences between the NSX and Legeng caliper is the NSX logo, and cooling fins. They are both two pot calipers. You can use the NSX caliper on ITR suspension.
Old Jun 27, 2003 | 07:08 PM
HYBRID's Avatar
HYBRID
arent legend rotors 5 lug?
