RPM limitation
Old Jun 14, 2003 | 09:42 AM
MetintegrA's Avatar
MetintegrA
Default RPM limitation
Hi there,
I just bought a modified integra GS. One of the mods is that the engine is not limited to 6800 RPM. Do you guys think it is dangerous? How high can I go in your opinion?
Thanks
Old Jun 14, 2003 | 11:13 AM
Kaiz's Avatar
Kaiz
Is there no rev limiter at all? The B18B1 block was only made to rev to 6800~7000...If you want to go higher, you'll need upgraded internals.
Old Jun 14, 2003 | 02:46 PM
Snoopy's Avatar
Snoopy
been there done that
i wouldnt go higher than stock redline with stock valvetrain unless you want your engine to go KABOOM!
Old Jun 14, 2003 | 03:06 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
On my b18a1 which is practically the same thing, i think the fuel cut off was 7100rpm's. Wouldnt rev any higher than that.
Old Jun 14, 2003 | 05:58 PM
98grnLS.'s Avatar
98grnLS.
thiers a rev limiter, ive hit it lil bit past 7100, i hit while racin through first and second, i think it hits at 7300, so your kinda safe cause you wont be able to rev up to 8 or wutever, unless they took the rev limiter out, which i dont know how you can do that so wutever.
Old Jun 14, 2003 | 08:40 PM
pomansouth's Avatar
pomansouth
in order to do that you have to get a new ecu if it is obd2 and a chip if it is obd1
