white smoke wtf!?
guys i haven an even bigger problem. Today when i was driving i noticed my bov sounded different and my turbo wasn't spoolin. I pulled off to the side of the road and poped the hood. Reved it a little and saw white smoke just pouring out. I do have a kink in my pil drain line. Could the oil be getting held up and making the white smoke? I was thinking it could be my seals on my turbo that are gone or my headgasket. any ideas?
Originally posted by LT6916
white smoke would contribute to coolant burning. Blue-ish smoke is oil burning.
i would say you blew a headgasket.
where's the smoke coming from?
DB Squad
Integra Forum Moderator
DB Squad
if you're having a boost creep issue, wont you see the boost gauge going over your set limit of boost?
either way, good luck...sounds like you're in for some headaches.
DB Squad
DB Squad
Originally posted by hollaback6
no because the boost is leaking out so it never reaches the manifold.
exactly why you would have a headgasket blown. the compression has dropped due to a broken seal between the head and the block. that would explain the boost leak and white smoke. I wouldn't drive your car until you can replace or at least have checked the headgasket.
Good luck man.
DB Squad
DB Squad
the boost leak is because there is a bolt missing in the i/c. I looked at the smoke closely and it has a tint. Looks blueish and a friend told me you can smell when the headgasket has been blown.
I do have a nasty boost leak i just discovered also. That could be overspinning the turbo causing the seals to leak.
