Integra Ignition Problems
First I wanna say, Slick site (i'm a web designer) 2nd, im having some starting issues in my 94 integra.
I've got a new coil, battery, plugs, wires, cap and rotor and still have starting issues. It only happens when it sits overnight in my garage. I get a click and then buzz but no turnover. If I turn the key twice really fast I get half an engine crank, then if fires right up the next try. Is my starter hosed? It's a 94 so it could be alotta things i guess... Thanks All
So once the starter decides to crank the engine, it starts right up? If so, I wouldn't call it 'ignition' problems.
First make sure you don't have any corrosion or loose connections on the big fat wire to the starter, or any of the ground wires. But it does sound like the starter. I'm guessing the starter solenoid pulls in but its contacts are dirty or else the starter motor brushes are worn out.
