any advice for B-20 modifications?
Old May 26, 2003 | 02:18 PM
dubcac's Avatar
dubcac
I
I'm with eddie, use the LS head, and get a 4-2-1 header of your choice. Some headwork, skunk2 manifold, crower valvesprings & retainers, cam gears, and some crower 404's. Throw a GSR tranny on that, and it'll be decently quick. It should be said that whether or not you use the LS head, you have to use the LS intake manifold since the B20 has the "giraffe" intake manifold.
If it was me, I'd either go turbo, or the above setup with some juice But I'm a nitrous fiend h:
Old May 26, 2003 | 07:19 PM
DOHCtor Jeckel's Avatar
DOHCtor Jeckel
thanks for the advice guys. I think I'm gonna stay all motor for now cuz im not even manual yet so it'd be a waste and a hazard (mis-shifting). If I move to texas I will most likely turbo it there, but for now I'm good. I might have to keep the b20 head for a while while i save up and have my ls head built and then put on. But yeah i have good insight now and goals to be accomplished. So hopefully all goes well with that x-member cuz i do plan on putting in a DC 4-1 header. Thanks again guys.
Old May 26, 2003 | 07:36 PM
dubcac's Avatar
dubcac
I
I would go 4-2-1, especially on an auto.
Old May 26, 2003 | 07:38 PM
Snoopy's Avatar
Snoopy
been there done that
throw on a gsr head h:
Old May 26, 2003 | 09:54 PM
DB7 2.0's Avatar
DB7 2.0
Banned
auto B20??? :happysad: at least you'll beat other auto LS's
skip the boltons and LS head, get a GSR tranny swap.
I/H/E = $600
LS head stock = $100
head port and polish = minimum $100
cam gears = $60
plus labor for install if you dont install yourself
or
GSR tranny = $600
LS manual ECU = $100
tranny swap is WAYYYYYYYYYY more worth the money and performance than boltons and a semi built head on an automatic teg. plus you can swap in the tranny while doing the engine swap to save more time in the future.
Old May 26, 2003 | 09:58 PM
dubcac's Avatar
dubcac
I
A good port job is going to be upwards of $4-500
I'm with eddie on the tranny swap.
Old Jan 5, 2006 | 02:54 PM
Driverman5777's Avatar
Driverman5777
Default LS Block B-20 head
How would the stock LS block be with the B-20 head. Would it be an improvement if ported and polished. or a waste of time
Old Jan 5, 2006 | 03:01 PM
AcuraFanatic's Avatar
AcuraFanatic
I agree. Screw the automatic, it saps the living bejesus out of the engine.
Old Jan 5, 2006 | 03:42 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Holy thread revival.
B20's suck, end of story.
Old Jan 7, 2006 | 11:06 AM
Patman015's Avatar
Patman015
Gold Member
'Specially since K20 is the way to go nowadays...and it isnt all that much more than the B20, and you get more options and more power. But, I mean it's totally up to the customizer, I'm def. not bashin anyone havin a B20 in an Integra!! I have to do some work to my B18 with 150xxx miles on it, and in my opinion, the work is worth saving the engine, even tho its only a B18.
