where exactly is the maint requird light resetter button located
Old Jul 2, 2002 | 07:52 PM
pomansouth's Avatar
pomansouth
Default where exactly is the maint requird light resetter button located
where is it under the dash and what does it look like i have a 98 integra rs and i just got oil changed today and i need to reset it. btw isnt mobil one supposed to be the best oil for your teggy
Old Jul 2, 2002 | 08:02 PM
KirkLS's Avatar
KirkLS
Wannabe ///M3 owner
Its under the drivers side of the dash. Put your hand down there and go directly below the steering wheel. Its a square button. Push it in and hold it until the light goes away
Old Jul 2, 2002 | 08:04 PM
95LSDOHC's Avatar
95LSDOHC
Ok, on my 95 lS it is located right underneath the steering column. Just get in the car, turn the key to battery, make sure not to turn it on. Then run you hand down the middle of the steering column till you reach the edge of the plastic panel, if it's any easier, you might want to look under the dash as you do this. You should see a square shapes box with a blue button in the center. while the car is still on battery(in park), hold it for 5 seconds until you see it (maintenence reguard light) turn off! hope the difference in the years of our cars doesn't effect anything. -Good luck-
Old Jul 2, 2002 | 08:38 PM
Excelesor's Avatar
Excelesor
Platinum Member
just stick your head under there with a flashlight and you should see a blue square button. then hold it down while you start you engine, it may go off the first time try, but do it again and then it'll go away.
Old Jul 2, 2002 | 09:41 PM
integramodder's Avatar
integramodder
thats the way i found it the first time :thumbup:
i thought it was green, not blue...maybe im just color blind :squint: / no memory
94acu_integ
5
Jan 31, 2005 06:39 PM
excitid
CRX & Pre 92 Civic
2
Sep 24, 2002 05:30 PM
blackTL
Engine Swaps, Tech & Tuning
Sep 15, 2002 07:54 AM
b12uceHuy
Accord
2
Aug 26, 2002 10:07 PM
