Regular or Premuim?
Old May 21, 2003 | 02:25 PM
The G2 Racer's Avatar
The G2 Racer
Want Boost!
When I had my GS-R I used Sunoco, 94 octaine.
With my new teg only 91.
Old May 21, 2003 | 02:57 PM
Daniel's Avatar
Daniel
I use the cheapest 94 Octane available. No pinging, knocking, or hesitation for me!
Old May 21, 2003 | 04:40 PM
DVPGSR's Avatar
DVPGSR
I need sleep...
Sunoco 94 when I can find one...otherwise the local BP has 93:thumbup:
Old May 21, 2003 | 07:30 PM
Chrgsr96's Avatar
Chrgsr96
Sunoco around here has 94 octane. But its expensive. So I just go with 93 normally which is still expensive.
Old May 21, 2003 | 07:37 PM
dom93hatch's Avatar
dom93hatch
more meat, more fire
I don't really discriminate between gas brands. I just try to stay away from the ghetto ones...the rest I really don't give a damn.
Old May 22, 2003 | 02:36 PM
NtenseB18's Avatar
NtenseB18
Up here in Seattle Washington 76 carries a brand called "Cool Blue" 100 octane. Pretty damn expensive though about 5 bucks a gallon. I use 91.
Old May 22, 2003 | 02:52 PM
cwhiteboy's Avatar
cwhiteboy
Yeah you can buy cool blue from 76 now. And by the way I work in the gasoline industry, and just to let you all know, all gas stations buy the same gas. Nobody has a better gasoline than anyone else, cause there all using the same gas, just which ever vendor is selling it the cheapest. And with amaco and other similar companies advertising that there gasoline has additives for better engine performance, thats only in the premium gas.
Old May 22, 2003 | 04:17 PM
Level_7's Avatar
Level_7
This is partly true. My father was a chemical engineer with Exxon (now Exxon Mobil) in Bahrain. There are _a few_ crude oil refiners/suppliers that _a few_ other secondary supplies use in the States and North America. So not all stations get their gasonline/diesel from the same place...however, there are strict regulations that control parameters like additives/rust inhibitors/accelerants etc in all fuel sold, so in the end you should be fine anywhere. Unless you know a place is sketchy, any place is adequate.
Old May 22, 2003 | 05:00 PM
Taiwanze7's Avatar
Taiwanze7
heh... 87 is good enough for my LS. but for you so cal pple, there is a 76 gas station off the 110 ending in pasadena that sells 100 Octane race gas ... I see pple fill up on it occasionally
Old May 22, 2003 | 05:47 PM
Chrgsr96's Avatar
Chrgsr96
There is a place near here that has gas called cam2 that i'm pretty sure is 110 octane.
