cold air intake installation help
take off strut bar,take of stock intake,take of resonater(in bumper),instal CAI
the air box has screws holding it in,and the intake is clamped onto the throttle body,the vaper return line is that hose going from your valve cover to your intake,reatach that to your new one,do not buy an air breather,unless you are turbo.
that help any? have fun
Originally posted by GSR9982
jdmfan.com/technical/performance/aem_intake/
these are pretty good instructions, I didn't have a problem
hey, this website you gave me doesn't work, can you check to make sure it is correct. thanks a lot
go to www.team-integra.net and register an account then go to the articles section. it has a full article with instructions and stuff on how to do everything!
You need to remove your front bumper...remove the strut bar (If any) remove the stock intake and resonator, remove the coolant resevoir and bracket, then you put the bottom part of the intake in first and then move the pipe around to get it to properly fit. Once you get everything stock of from the stock intake putting the CAI on is very, very easy!
Originally posted by dom93hatch
You don't need to remove the front bumper. It can be done without having to do so.
