jdm and usdm
Old May 7, 2003 | 08:13 PM
static's Avatar
static
Default jdm and usdm
Will usdm B18c1 aftermarket parts(intake, exhaust, turbos,etc.) fit a jdm B18c1. Also, will B18c1 aftermarket parts fit a B18c5.
Old May 7, 2003 | 11:00 PM
HONDAmail.net's Avatar
HONDAmail.net
I believe B18c1 usdm and jdm parts fits well
Old May 7, 2003 | 11:04 PM
Teg711's Avatar
Teg711
Purge This...
Old May 8, 2003 | 05:48 AM
DVPGSR's Avatar
DVPGSR
I need sleep...
All B18C parts are interchangeable with the exception of the intake manifold. The bolt pattern for a B18C1 is different from a B18c5 or JDM B18C ITR engine. Also parts from the B16A Civic Si and the CTR (not certain about engine code) will also fit.
Old May 8, 2003 | 11:49 AM
TheRooster's Avatar
TheRooster
Former Senior Member
What about the exhaust manifold? Would you use a USDM GS-R bolt pattern or an ITR bolt pattern for the head... on a JDM B18C1?
Old May 8, 2003 | 11:52 AM
DVPGSR's Avatar
DVPGSR
I need sleep...
The exhaust bolt pattern is the same on both. On a B18C1 I am going to use my head with the Skunk2 IM and port and polish both so they match up together correctly.
Old May 8, 2003 | 11:55 AM
TheRooster's Avatar
TheRooster
Nice! Thanks!
wait... do you mean the B18C1's are the same, or the B18C1 and the B18C5 are the same? I've been looking at the Type One 4-1 to pair up with my edelbrock intake.
Old May 8, 2003 | 01:23 PM
Stealth 95 GS-R's Avatar
Stealth 95 GS-R
TROGDOR the BURNiNATOR
most CAI's are not interchangeable between Type R (C5) IM and GS-R/SiR-G IM.
-Andrew
