Most Recent Problems
Old May 7, 2003 | 09:25 PM
FURIOUSGSR01's Avatar
FURIOUSGSR01
FURIOUSRSX04
we all know everybody's biggest problem is picking out what car to get next, after our integra's die..
Old May 7, 2003 | 11:32 PM
ChopSticks's Avatar
ChopSticks
Originally posted by drumsy
Shorter lifespan on radiators due to plastic, not aluminium, endpieces.
My radiator is leaking mad coolant because of that plastic shit
Old May 8, 2003 | 12:13 AM
airon's Avatar
airon
AARONNOJIMA.COM
cam seal (94-97s)
hatch rattle (fixed now )
window rattle (will fix when i have time)
draws to much attention (good/bad thing)
everything else is cool, just gotta stay up on regular maintenance
Old May 8, 2003 | 06:01 AM
gradebg96's Avatar
gradebg96
i just got mine, has 162k miles on it, she's has antena problems, the windows rattle when you close the door, the radiator has been replaced, timing belts, u need an oil change every 3k miles like every car, the AC has been messed up since about 30k miles, and been replaced a few times, auto.consumerguide.com lists the general problems with integras, there's not many but the obvious ones listed here
Old May 8, 2003 | 01:21 PM
Stealth 95 GS-R's Avatar
Stealth 95 GS-R
TROGDOR the BURNiNATOR
hatch rattle (fixed with duct tape), sunroof rattle (don't care), power antenna (S2000 kit, then I got hit, so I shaved and filled in the hole), exhaust cam oil seal (about $5 to fix), radiator weak (BAR's Leak fixer $2), some GS-Rs get a cracked header (buy a new header), rattling heat sheilds (tear 'dem shits off). Thats about all I can think of now.
-Andrew
Old May 8, 2003 | 07:15 PM
Singhg83's Avatar
Singhg83
BALLIN'
how did you fix the hatch with duck tape, & where?
Old May 8, 2003 | 09:26 PM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
I believe you wrap the tape around the metal loop of the trunk latch. I didn't want to do that, so I slightly unscrewed two of the rubber stoppers on either side of the trunk (Didn't want tape gunk all over the lock mechanism).
You can (I believe) also re-align the actual locking mechanism that lies between your two taillights... but that's a lot of work...
