oem kit
Old May 2, 2003 | 10:22 AM
Shingoblade-GSR's Avatar
Shingoblade-GSR
Hellsing Agency
Originally posted by Turd_Fergason
thanks Shigo, I found the frony lip online, and I was wondering other than the obvious fact that urethane is better, will a fiberglass kit hold up and have a good fit.
Well I got my lip from the factory; I believe the factory uses some sort of hard composite plastic or whatnot (bit softer than fiberglass). Fiberglass will actually hold up better (the paint will be less prone to fade) but if it's not a *near* perfect fit it may give you some headaches. It'll also be more prone to cracking/breaking, so you have to be extra careful when driving over bumps and whatnot. Comptech uses urethane for their front ITR lip, so that's probably your best bet, although the price is a bit steep.
Shingo
