Help!
Old May 2, 2003 | 11:15 AM
JimBlake's Avatar
JimBlake
I think if you had bent any valves, you'd notice a real drop in power, nothing subtle about it. You could measure compression, that'll be pretty bad if you have a bent valve.
Old May 2, 2003 | 01:03 PM
rustybody's Avatar
rustybody
i did two compression tests. ended up with 209, 204, 206, 213.
is it possible i flooded it? what else can these numbers mean? everything seems to run fine.
Old May 5, 2003 | 03:45 AM
JimBlake's Avatar
JimBlake
Those look like pretty good numbers. I can't believe you have any bent valves with pressures like that.
Old May 5, 2003 | 06:58 AM
dom93hatch's Avatar
dom93hatch
more meat, more fire
Those numbers are WAY GOOD for a B18B with 219k! :thumbup:
Old May 5, 2003 | 09:17 AM
rustybody's Avatar
rustybody
