idle..
Old Apr 26, 2003 | 03:24 PM
cu3tip's Avatar
cu3tip
Default idle..
hey guys ,i was just curious latley my idle has been kinda shakey in reguards to like the steering wheel, like when im sittin at a stop light it kinda vibrates a little more then i always have noticed..... but on my tach my rpms are stable at like 5-700..
but do u guys have any ideas on checking this???
Old Apr 26, 2003 | 03:28 PM
gregz93integra's Avatar
gregz93integra
Banned
new spark plugs will probably help...
Old Apr 26, 2003 | 03:33 PM
cu3tip's Avatar
cu3tip
i already have new spark plugs and spark plug wires..both NGK's
Old Apr 26, 2003 | 03:36 PM
90'RS's Avatar
90'RS
How's your cap, rotor, and coil doing? These are also somethings to look at. These are somethings to look at when the idle is jumping a little bit. Just for the wheel shaking I would suggest looking at the engine mounts real close making sure all the bushings are in good shape.
Old Apr 26, 2003 | 04:26 PM
cu3tip's Avatar
cu3tip
ya i just replaced my cap, and coil so i think there ok..
Old Apr 26, 2003 | 07:58 PM
MikeR's Avatar
MikeR
sounds like motor mounts, if rpm's are steady it doesn't sound like a performance issue, i would think the vibe is feeding back through the steering wheel and or suspension
Old Apr 27, 2003 | 07:26 AM
newgsrdriver's Avatar
newgsrdriver
Check your mounts to see if theyre torn. Specifically the lower torque mounts.
Old May 19, 2003 | 05:13 PM
96GreenCivic's Avatar
96GreenCivic
i have the same issue with vibration in the steering column. Sometimes the vibration moves from the column to the cabin. Are mounts easy to fix as a DIY or how much would it cost for me to get someone to do it for me??? Suggestions?
