Tockio shocks with Ground Control
Old Apr 19, 2003 | 02:42 PM
FURIOUSGSR01's Avatar
FURIOUSGSR01
FURIOUSRSX04
Originally posted by winston
The guys who installed them said they were supposed to be so stiff. I gave up on them so asked to have originals or if they could get ground contol spring same as stock , I would be happy. They, Motorsport Dynamics said no, so originals went back in.
That doesn't make any sence? Didn't you know you could have easily raised the car back up by yourself?
Old Apr 19, 2003 | 03:48 PM
Shingoblade-GSR's Avatar
Shingoblade-GSR
Hellsing Agency
No one runs their coilover setups on the lowest setting for the street. You'll need to use shorter and stiffer springs to do that. Do you still have those coilovers? Adjust them to a reasonable setting and you should be fine. (I'm assuming they're adjustable....)
Shingo
Shingoblade-GSR
Hellsing Agency
Old Apr 19, 2003 | 06:08 PM
winston's Avatar
winston
thanks shingo,
i wish i still had them, but I do not....
Old Apr 19, 2003 | 07:24 PM
SLaMmEd GsR's Avatar
SLaMmEd GsR
Originally posted by mysterio
I have tried alot of setups, and by far the best on my '95 LS is the Tein SS. Nothing compares to them.
The tein ss setup is badass for an integra. Although i can't afford that setup i'm running the tokico illumna coilovers and they ride pretty good, even with the springs on the lowest setting.
Old Apr 20, 2003 | 05:15 PM
winston's Avatar
winston
Default Ground Control C/O and Illuminas
I was extremely nervous about the way the car was behaving. I did not know how to adjust the c/o's for ride height, or how to adjust height correctly side to side and front to back. Does one need to use corner weights to set up the heights?
Perhaps if I had had more information about the c/o's and how to set them up, I would be driving with them today. For my next venture I will be sure to make the most of this asset, namely the experience and knowledge of the members to this site.
Thank you all.
Winston
