GSR Trans on a Ls
MIDDLE AGED CRAZY
I took my 94 LS in to have some transmission work done. Turned out that the repairs would have been almost as much as a tranny swap. I was talked into a GSR tranny with only 30k miles on it. I also replaced the clutch with a new one.
The first thing I noticed was how much more robust 3rd 4th & 5th gears were due to being geared lower than the LS tranny. After a couple of days of break in I tested it on the way to work. I live on the central coast of California and drive to Vandenberg AFB on the back roads.
Some places get windy and hilly. I noticed that I could pull out of 5th gear on a paticular hill where before it would bog down. On straight roads when I dropped to 4th gear to pass cars it would hit 90 before I knew it when before I would only reach 80 with the same amount of effort at the peddle. I would estimate that with the GSR tranny you could shave 2 or 3 tenths off 1/4 mile times.
The ratios for a LS & GSR are:
LS GSR
1st 3.230 3.230
2nd 1.900 1.900
3rd 1.269 1.360
4th 0.966 1.034
5th 0.714 0.787
LS GSR
1st 3.230 3.230
2nd 1.900 1.900
3rd 1.269 1.360
4th 0.966 1.034
5th 0.714 0.787
Banned
just for a point of reference....
an old member of this board had a civic coupe with a bone stock as can be LS engine with a GSR tranny.
as is, he ran dead solid high 14s. (i think it was 14.8 from what i remember)
a GSR tranny swap in my opinion is way better than an intake/header/exhaust combination and costs just about the same as well.
u r teh sux!!1!111!
ugh.. i wish i wouldve known where to buy transmissions when i bought mine.. mine sux, 3000rpm at 60 in 5th, 3rd gear is where i start to lose speed gains, typical ls tranny though huhh:
tranny was a turd too, 3rd gear synchro is going out, 2nd is starting, too bad the warranty was only 3 months
can you just buy the gears for the GSR and put them in the non v-tec trany. My car's going to be in the shop in about 3 months until winter's over. I'll have alot of time to rebuild the trany.
