Vibration/Shaking
Old Apr 5, 2003 | 11:43 PM
phawx's Avatar
phawx
Default Vibration/Shaking
Anyone have any ideas one why my car starts to vibrate and shake a little bit, when i start doing about 80mph? Im thinkin it's either the wheels or the engine it self.
Stats:
Car: 1990 Acura Integra LS
Miles: 195,000
Tires: 195/60R14
Anyone Have Any Ideas.....
Old Apr 6, 2003 | 07:17 PM
newgsrdriver's Avatar
newgsrdriver
Check to see if any weights have fallen off of your wheels that has caused them to be imbalanced. Thats the first thing.
Old Apr 7, 2003 | 09:26 PM
phawx's Avatar
phawx
never even thought about that, i will have to check into it, thanks
Old Apr 8, 2003 | 04:53 PM
phawx's Avatar
phawx
well, i dunno where the weights would be on my rims, hehe, there are no visible ones....they don't normally put them in the tires do they?
Old Apr 8, 2003 | 04:58 PM
90'RS's Avatar
90'RS
The weights will be on the inside of the rim (the side that faces the engine) and if they are aftermarket wheels then the stick them on the flat part. If they are stock steelies they usually stick them on the inside lip.
Old Apr 8, 2003 | 05:00 PM
phawx's Avatar
phawx
damn it, so much work, im working on gettin new wheels though...hehe.
Old Apr 8, 2003 | 05:07 PM
90'RS's Avatar
90'RS
If you have the stock steelies on there still then you should be able to run your hand across the back and feel if the wieght is back there, so you don't have to take the rim off.
Old Apr 8, 2003 | 05:09 PM
phawx's Avatar
phawx
mine arnt stock
Old Apr 8, 2003 | 06:57 PM
Level_7's Avatar
Level_7
I don't think it's the weights in the wheels. Check things like front end alignment, correct toe-in and camber, worn/wearing hub bearing, worn cv joint.
Old Apr 8, 2003 | 07:04 PM
Mikey_C's Avatar
Mikey_C
Im gonna guess if it gets more noticable at higher speeds than its wheel balance-what wheel weights are there for
if it really bothers you you can get wheels balanced for like 10 a piece ask a tire guy you trust to take a look for you.
but if there is a wheel with no weights at all i would get that one balanced
