fuel rail help......
Old Apr 2, 2003 | 03:04 PM
whiteinte95's Avatar
whiteinte95
Default fuel rail help......
I need some advice on removing fuel rail and installing new one. Can i reuse the old injector o rings. thanks
Old Apr 2, 2003 | 03:56 PM
90'RS's Avatar
90'RS
I have reused them before in a previous car of mine and don't see why it wouldn't work with the tegs too. Just be sure to grease them up with something so they slide back in real nice, I just used a little oil and it did the trick. One thing to consider though is how old are they now becuase my old car only had 70k or so and I'm sure the mileage can affect these.
Old Apr 2, 2003 | 09:16 PM
whiteinte95
What about actually removing the injectors from the intake manifold, do they just pull out or what?
Old Apr 3, 2003 | 08:29 PM
B18C1TEG's Avatar
B18C1TEG
yea u just have to pull em out, they're in there kinda snug but it doesnt take much it get the out.
Old Apr 4, 2003 | 01:19 PM
JimBlake's Avatar
JimBlake
You might find that the O-rings have got hard from age & heat. I'd put new ones in, but you might get lucky.
Old Apr 6, 2003 | 10:10 AM
whiteinte95
Ok i just removed my fuel rail and injectors and this is what i found. 2 of the injectors were missing the screens at the top and 2 of the injectors o rings were busted. Its sunday and the dealer is not open to get the parts. Should i get new screens for all the injectors or should i just take the others out? How much would the o rings cost for the injectors?
What would be affected if o rings were messed up? (the ones between the injectors and the manifold) Would fuel pressure change or anything.
Old Apr 6, 2003 | 11:16 AM
90'RS's Avatar
90'RS
I would replace all the screens, if possible, and just go ahead and replace all the o-rings to all of them. This way you know they are good for the rest of it's life. The dealer should sell a o-ring kit for replacing those but the screens I have never seen them for sale before and that's why I said if possible. As for the price the o-ring kit from say advanded autos would be about $15.
Old Apr 6, 2003 | 03:10 PM
whiteinte95
Acura is like 50 minutes away, but hondas like 5 minutes away, will honda have the same part that is used for the del sol or civic or something that will fit my gsr manifold
Old Apr 6, 2003 | 07:05 PM
newgsrdriver's Avatar
newgsrdriver
Take an injector to Honda and ask them what car uses the same 240cc's as yours, and possibly the o-rings are interchangeable. B16 maybe, I dont remember the injector size.
I actually went to Home Depot once when I was in a pinch and used one of the o-rings there. It was a bit tight, but has worked fine for a while now. Just grease them up a bit with some oil.
