Help!! Got Flatbeded home
Old Mar 30, 2003 | 06:11 PM
matty1821's Avatar
matty1821
Default Help!! Got Flatbeded home
I need some help, I got a 94 gsr. Last night it started acting up. Here is what is goin on. When i try to turn over the motor it turns and turns then barely fires up. But it fires up fine when it was cold out (which happened this morning) After that it revs fine when its cold. I let it warm up and then i am getting sputtering, like not enough fuel, spark or vacum. But its fine from 3k on. When i try to move it bogs down terrible and have to keep reving just to go and its like putt putt putt and then finally creeps up in the rpms. Some ideas would help greatly. (I had my timing belt, water pump, and fuel filter changed) Dont have much done either. I/H/E plugs, wires. No major engine work and timing is stock.
Old Mar 30, 2003 | 06:58 PM
reno96teg's Avatar
plugs? rotor? distributor cap? when's the last time you did these?
Old Mar 31, 2003 | 07:12 AM
matty1821's Avatar
matty1821
just put on MSD wires and Bosch +4 about 4 months ago
I dont know when or if the distrib cap or rotor was changed. I bought the car used about 8 months ago
Old Mar 31, 2003 | 07:25 AM
matty1821's Avatar
matty1821
could it be a vacum line somewhere, fuel injectors? I ran redline fuel system cleaner through it yesterday, and ran royal purple before
Old Mar 31, 2003 | 08:58 AM
DB7 2.0's Avatar
DB7 2.0
Banned
bad coil? :dunno: thats what my car's problem was last year.
Old Apr 1, 2003 | 09:34 AM
red.da's Avatar
red.da
if it was a bad coil it wouldnt start at all.
check your cap/rotor, change the fuel filter if you havent before. when it idles does it sound real rough? check and see if all your spark plugs are firing. it might be running on 3 cyls. maybe one of your plugs isn't getting a spark or one of your injectors isn't giving fuel.
Old Apr 1, 2003 | 03:05 PM
XSrcing's Avatar
XSrcing
what about your thermostat? if it is stuck closed, your engine may be getting very hot, but the temp sensor which is on the radiator wont show it.
Old Apr 1, 2003 | 05:30 PM
DB7 2.0's Avatar
DB7 2.0
Banned
well depends on how bad the condition of the coil is. mine was bad enough to irritate the fawk out of me while driving and starting it up. but it wasnt to the point where it wouldnt start up at all. but it was probably almost there h:
Old Apr 2, 2003 | 03:57 PM
matty1821's Avatar
matty1821
Fuel filter is fine, just changed about a month ago. One friend told me an air idle control valve. I never even heard of it. I am praying its not a vacum line under my intake manifold. If it were to be which one does this sound like and any other suggestions would be great.
Old Apr 21, 2003 | 02:15 PM
GreenEggs248's Avatar
GreenEggs248
Have the same problem, does anyone have an answer?
