Car won't accelerate past 5000 rmp...
Old Mar 29, 2003 | 08:45 PM
jason78240's Avatar
jason78240
Default Car won't accelerate past 5000 rmp...
I have a 00 GS-R with about 58,000 miles on it. Today when I was driving, I tried to accelerate, and as soon as I hit 5,000 rpm (VTEC engagement) my check engine light came on and I cannot get passed 5,000 rpm. Drivablility under 5,000 is normal, but I cannot go above. Last month I advanced my timing a bit and adjusted my valve lash, so I don't know if that may have something to do with it. Please help !!!!
Jason
Old Mar 29, 2003 | 09:22 PM
Taiwanze7's Avatar
Taiwanze7
Sounds like your teg has gone into limp mode.... obviously VTEC won't kick in, some possible things could be low oil pressure, or engine hasn't warmed up yet
Old Mar 31, 2003 | 05:49 AM
stevieteg's Avatar
stevieteg
That happens to mine when the motor is too cold.
Old Mar 31, 2003 | 09:31 AM
Chrgsr96's Avatar
Chrgsr96
check your oil, i know that when your oil is low vtec normally will not engage. or it could be something else thats probably much more compliacted?
Old Mar 31, 2003 | 10:31 AM
Daniel's Avatar
Daniel
I would definitely check the code and see what it's telling you. Low oil pressure could be the problem, even a bad VTEC solenoid if this is a constant. Have you ever been able to go into VTEC lately?
Old Mar 31, 2003 | 09:51 PM
XSrcing's Avatar
XSrcing
welcome to limp mode! what code did it throw?
Old Apr 2, 2003 | 12:54 AM
Shingoblade-GSR's Avatar
Shingoblade-GSR
Hellsing Agency
Yeap, the oil is cold and hasn't had the chance to circulate to all vital moving parts. The check engine light is probably a different issue altogether though.
Shingo
Old Apr 2, 2003 | 08:00 AM
jason78240's Avatar
jason78240
Finally got around to checking it out, and my oil level was pretty low. Filled it back up and everything is ok. The CEL code was 22, and as soon as I reset the computer it stay off.
Old Apr 2, 2003 | 08:35 AM
DelSolSIinMD's Avatar
DelSolSIinMD
Le Grand Illusion
How low? Are you leaking it, or burning it ... ? You should check that out so this doesn't happen over and over...
Old Apr 2, 2003 | 08:35 PM
XSrcing's Avatar
XSrcing
22 is a VTEC solonoid switch malfunction, and is usually caused by low oil leverl, as in your case.
