AcuraLsSE mini build thread
Old Aug 27, 2010 | 10:14 AM
  #71
Lynxs1981's Avatar
Lynxs1981
Yea. They have the transmission side case with the gears and the clutch side case that bolts to the motor.
Old Sep 13, 2010 | 10:22 AM
  #72
AcuraLsSE's Avatar
AcuraLsSE
ASE Certified
Still haven't put any music on the video... About to just upload it without any. But I was bored yesterday and did a compression test on the new engine. All numbers were dead on 220 psi so I'm happy to see that all the rings set evenly.
Old Sep 13, 2010 | 03:51 PM
  #73
Spec R's Avatar
Spec R
i hate it when people put music on car videos. im there to watch the car and listen to the motor/exhaust. haha
220 across? dang thats pretty high for a non-vtec
DB Squad
Integra Forum Moderator
Old Sep 14, 2010 | 12:51 AM
  #74
AcuraLsSE's Avatar
AcuraLsSE
ASE Certified
Yeah I think I'll just keep it simple and not add music.
Isn't 220 psi around where I should be with these pistons? I thought it was like 220-225 psi or something.
Old Sep 14, 2010 | 05:49 AM
  #75
Lynxs1981's Avatar
Lynxs1981
First glance I was thinking they were low numbers because mine are right around 300; but then I realized B18b. Stock numbers are right around 200 for yours, so with the ITR pistons you're running pretty healthy numbers. C1/C5 numbers are 270.
Old Sep 14, 2010 | 10:14 AM
  #76
AcuraLsSE's Avatar
AcuraLsSE
ASE Certified
Well its been a while since I've done a compression test. I cranked it over 5 times for each... how many times did you crank yours over? Maybe I should do it again.
Old Sep 14, 2010 | 10:40 AM
  #77
Spec R's Avatar
Spec R
i dunno, whenever i did, i always pulled all the plugs, then on the first one, cranked until it didnt go any higher. then cranked the same amount on the rest of them.
DB Squad
Old Sep 14, 2010 | 03:34 PM
  #78
Lynxs1981's Avatar
Lynxs1981
Plus holding the throttle all the way open. I wouldn't worry too much about it. You have nice numbers there.
Old Sep 15, 2010 | 03:09 AM
  #79
AcuraLsSE's Avatar
AcuraLsSE
ASE Certified
When I was in school they said 3 to 5 cranks so I did 5. I disabled the spark and fuel, had all spark plugs out, and the throttle all the way open.
Old Sep 27, 2010 | 02:48 PM
  #80
AcuraLsSE's Avatar
AcuraLsSE
ASE Certified
My lazy ass got around to posting the video...
