I'm Grinding!!!
Old Mar 11, 2003 | 06:31 PM
qtiger's Avatar
qtiger
Originally posted by antarius
qtiger,
It does say in my Helms manual that you can use Motor Oil as a temporary replacement for Honda MTF.
I know. It's the same weight and can perform the same function for a short time, but doesn't have the additives required to protect your transmission's components from wear.
Old Mar 11, 2003 | 06:38 PM
antarius's Avatar
antarius
Large Member
Yup, exactly. It is definitely designed for Honda MTF and the Engine Oil replacement is only supposed to be used as a temporary replacement in case of an emergency.
In any case, go get some damn Honda MTF (not Redline either) and change that ish!
Old Mar 11, 2003 | 07:45 PM
mgilmore's Avatar
mgilmore
I'm not sure if this is related, but when I start off in first and shift to second, I get a screaching sound. I'm not exactly sure what's causing it, but it's really anoying. I thought it might be my belts, so I had them changed, but still have the problem. I'm gonna get the transmission fluid tomorrow and see if that solves the grinding problem. Any solutions or ideas will be appreciated. And thanks to all that replied!
While we're on the topic, I was wondering if anyone knows if a turbo kit coming from early 90s eclipse would do any justice on my 94 integra ls engine. Excluding the grinding problem! I also have a 97 gsr clutch that I plan on using. Any thoughts or ideas, please feel free to speak your mind!
Old Mar 12, 2003 | 03:54 PM
Tony96EX's Avatar
Tony96EX
I heard Redline MTL is actually good or better than Honda MTF for Honda trannies. But I've never tried it, so I am not speaking from experience.
Old Mar 12, 2003 | 04:11 PM
91integrals's Avatar
91integrals
u r teh sux!!1!111!
You can do searches on the boards about used turbos from diff cars, theres countless threads on em.. but from what i hear, older eclipses turbos work ok on integras...
Old Mar 12, 2003 | 04:38 PM
Zedron's Avatar
Zedron
Turbo B20
where can i get Honda MTF? From a dealer or what?
Old Mar 13, 2003 | 10:06 PM
Phillyphil81's Avatar
Phillyphil81
ok guys sorry to say this but get that fixed. I have the same thing happening to my teg and now i have no third. changed the oil did all that shit, nothing worked just send it out to get new synchros and save your self from buying a new tranny.
Old Mar 14, 2003 | 07:16 AM
LudeRage's Avatar
LudeRage
My 90 GS sometimes won't even go into first or second gear. I have to fugging slam it. Also it grinds majorly sometimes even when the clutch is fully engaged. Not sure what the problem is, but I'll be taking it to a mechanic on Tuesday to see what he thinks. Either way, I'm trying to use this as a way for my mom to lend me money for an ACT HDSS
Old Mar 14, 2003 | 12:45 PM
qtiger's Avatar
qtiger
Sounds more like you should ask for a new transmission with the way you've been treating it.
Old Mar 14, 2003 | 02:58 PM
Daniel's Avatar
Daniel
Check out the latest edition of Honda Tuning. I believe they do a junkyard boost segment on mating a Mitsubishi turbo to a Honda.
