clutch problem
well i dunno if its really a problem, my clutch was just installed less than a month ago.. at first it was great for first few weeks drove it easy and broke it in properly.... but now since like a week ago, my clutch is engaging about an inch higher than it was befor... also where it use to engage, the clutch gets alittle tightened up... now it gets tight even when im in neutral releasing the clutch and i hear clicking sounds if i release slowly.... the clutch was brand new exedy, and proffesionaly installed... any ideas? thanks guys
mechanical or hyd clutch, either way adjust your clutch, most are simple, a pedal adjust will work. If it is hyd, you may have been low on fluid before the new clutch, and now it is where it should be. Check your fluid to make sure it is not overfull as well. Most likely a pedal adjustment will work.
mosh
mosh
