wheel hub removal / replacement
Old Mar 1, 2003 | 11:36 AM
tilt's Avatar
tilt
Default wheel hub removal / replacement
Im going to be removing the front wheel hubs on my 94 integra soon. They have bad studs (stripped) and the wheel bearings I believe are on their way out.
I am looking for detailed instructions or a how-to on this. More specifically, I need to know what particular tools i will need.. such as separating the knuckle from the wheel hub. and pulling and putting on the new wheel bearings.
Here are the steps that I know to do:
1 remove 32mm axle spindle nuts
2 remove rotor
3 separate lower ball joint
4 press/separate the axle out of the hub
5. set the brake/caliper assembly to the side
6. what do i do from here??
tia
Old Mar 1, 2003 | 07:02 PM
gsr2k's Avatar
gsr2k
I don't know the answer to this right now - I have to do it this week sometime to fix a bent knuckle. If you dont get an answer by midweek, let me know and I'll help you out.
When you're removing the brake aseembly, be very careful not to break the ABS sensor. Apparently they get kinda sensitive after the years pass.
