Best AFFORDABLE aftermarket radiator...
I've gotta replace the radiator on my '91 LS coupe, but don't want to go back with the oem plastic one. I'm also not ready to drop $400+ on a high performance one.
Any suggestions on the best of the affordable all-aluminums out there.
Thanks.
Thanks.
You may want to try searching next time (I actually had the same question as well):
https://www.honda-acura.net/forums/s...arket+radiator
And from H-T:
http://www.honda-tech.com/zerothread?id=219217
The prime choice here seems to be the PWR -> $300, which is still steep but under your price cap.
Shingo
And from H-T:
Shingo
There's no such thing as a radiator above and beyond OEM or OEM-equivalent that is not a "high performance" piece. The PWR is nice, and sometimes you can find a Koyo all-aluminum one for about $350.
There's nothing inherently wrong with the stock design, and if you think about it the one you've got has lasted this long so replacing it with a similar piece can't be that bad if you're in a pinch for the dollar signs.
