ground straps
Old Feb 24, 2003 | 07:52 PM
97teg's Avatar
97teg
Default ground straps
Hey everyone Ive been looking at little things to improve the performance and one of the things i have come across are the "earth grounding system" http://www.optauto.com/webstore/prod...tion=&back=yes
Has anyone used this? Can this really add that much? Hks makes them too but I have no clue how well they work.
Old Feb 24, 2003 | 08:11 PM
DB7 2.0's Avatar
DB7 2.0
Banned
i think it will only work depending on the condition of the current engine's setup.
Old Feb 24, 2003 | 08:25 PM
97teg's Avatar
97teg
Well my car is an 97 rs 5 speed ngk wires ice box 63,000 on it. Spoon strut bar but that has nothing to do with the engine.
Old Feb 24, 2003 | 09:11 PM
b00gers's Avatar
b00gers
depends on the condition of the current grounding system...
if the grounds on your engine or battery sucks ass or is dirty...yes, there will be a difference. if you keep your grounds clean, i say the difference is minimal if any.
if you can crimp, make your own wires h: its way cheaper.
Old Feb 24, 2003 | 09:20 PM
Kai's Avatar
Kai
Rotorphile.
Seriously, go to Home Depot and get some 2ga insulated stranded wire, then go to a car parts store for some 2ga rings. Cut, crimp, and bolt on. It will do the exact same thing, but I'd be suprised if it costs more then $10.
Old Feb 24, 2003 | 10:07 PM
97teg's Avatar
97teg
Yeah i would do that but i don't know all the points that they connect to. Does anyone know where the connect besides the factory points?
Old Feb 25, 2003 | 04:10 AM
ur31337's Avatar
ur31337
Colby
I know a couple of the Type R guys at Honda-tech used them and actually saw an improvement. They spent like $100 or something though. I could dig up a thread if it really came down to it, but search over there.
Improved throttle response and a bit torquier, supposedly.
Old Feb 25, 2003 | 10:23 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
I wouldn't waste your time yet if you have made no modifications to the motor.
Old Feb 25, 2003 | 10:31 AM
b00gers's Avatar
b00gers
i bet if you search the forums long enough...you can find out exactly which wires their swap out....
ones worth mentioning...i did because i use to have a fat stereo system.
battery-ground
alternator-ground
engine head-ground
Old Feb 25, 2003 | 11:23 AM
97teg's Avatar
97teg
I have some extra 4 guage power wire form an install. I was wondering if the engine temps will be too much if i use it on the engine block ground or if it would be ok.
