98 GSR Check Engine Light ?
Old Oct 14, 2009 | 08:28 AM
gingas's Avatar
gingas
Default 98 GSR Check Engine Light ?
Hows it going. Seeing if anyone can help. I gave my GSR a TB clean & cleaned my manifold also. I took off the intake to clean the TB while car was off then running. I then removed the rubber hose thats connected to the mannifold and sprayed my manifold cleaner while car was running. I sprayed several times. Car would idle then rev to 3K each time then re installed hose on manifold.
When I went to cut off car my check engine light was on & wont go out. It makes a little strange sound idiling which is from light being on. How do I go about having my check engine light turned out.
Thanks Very Much
Old Oct 14, 2009 | 09:38 PM
Spec R's Avatar
Spec R
well you have to find what caused the light to turn on in the first place, then address the problem.
DB Squad
Integra Forum Moderator
Old Oct 15, 2009 | 01:07 PM
Lynxs1981's Avatar
Lynxs1981
I would start with resetting the ecu. Pulling vac lines that way probably tripped the CEL for a high idle.
Old Oct 18, 2009 | 08:51 AM
gingas's Avatar
gingas
Good looking . I went to work and pulled up engine code and cleared it. Went on when I cleaned my manifold & idle went up to3.
Old Oct 18, 2009 | 02:24 PM
Lynxs1981's Avatar
Lynxs1981
What was the code?
