Fuel Pump / Relay
Old Sep 22, 2009 | 06:25 PM
sleeper13's Avatar
sleeper13
Default Fuel Pump / Relay
I was told by a mechanic that my fuell pump was dead which is why my car wasn't starting. I replaced the pump, filter, and strainer, and still no start. A friend of mine who helped me install this, said it cud be my relay which is causing the problem.
if anyone has any ideas on what the problem might be please let me know. I didn't get the enjoyment out of my car yet cuz i havent had it that long
Old Sep 23, 2009 | 03:37 AM
MonteC's Avatar
MonteC
Transmission Guy
Could be the relay. I had a problem with my car that if i drove it for more than 10 minutes or so and shut it off it wouldnt start back up immediately, it would have to cool down for hours.
The relay would get hot and stick off when the car was shut off, after it cooled down the relay would switch back on when i turned the key. Replaced the relay and no problems since. It wasnt that expensive from Rock Auto, none of the local parts stores had it, im sure honda/acura will have it.
Old Sep 23, 2009 | 06:03 AM
Lynxs1981's Avatar
Lynxs1981
I would check the relay, also there's a few fuses I would be checking first.
Old Sep 26, 2009 | 04:31 PM
cruzalekz's Avatar
cruzalekz
could be just a plugged up fuel filter.
check fuel pressure, check spark
Old Nov 1, 2009 | 02:14 PM
joe_kewl81's Avatar
joe_kewl81
remove your air intake and spray fuel into the throttle body, if it fires, your fuel isnt getting to your engine, if it doesnt fire, its not fuel related.
