changing belts
Old Feb 14, 2003 | 02:31 AM
el diablo's Avatar
el diablo
Jeeebus......Help Me!!!!!
Default changing belts
I need to replace the ac compressor pump belt and the power steering pump belts. Can anyone give me a heads up on how to start this or some site that might explain it. I looked it up in the Hayse Manual that I have but it doesnt get into too much detail for changing belts.
Thanks for the help.
Old Feb 14, 2003 | 04:10 AM
pomansouth's Avatar
pomansouth
you might wanna check c-speedracing.com
Old Feb 16, 2003 | 03:54 AM
newgsrdriver's Avatar
newgsrdriver
Theyre straightforward.
You need to remove the lower mount to replace the AC belt...not difficult. There is a tensioner pulley that you loosen from the front right below the power steering...a 10mm bolt in a 12mm nut I believe. Loosen that, remove mount, remove belt, replace belt, tighten tensioner.
PS Belt is 2 12mm if I remember right, and a wingnut. Loosen bolts & wingnut, drop the unit, remove belt, replace belt, bring back up and tighten.
Old Feb 16, 2003 | 11:55 AM
el diablo's Avatar
el diablo
When you say lower mount do you mean motor mount or is it a mount for the ac compressor??
