92-93 clutch question
I have a 93 ls and it has 133,XXX miles on the clutch so it should be going out some time. So my question is, do the 92-93 gsr clutches have a higher clamping force than the ls clutches? I'm assuming that they are b-series the clutch would work, right? Just getting prepared for what to get when it decides to go out.
Since no one seems to know here I'd email or call some shops for their opinions.
But I'd assume the G2 GSR clutches have more clamping force. But I am not sure if the G3 clutches would fit on a G2 tranny. Not totally sure though. Call a shop and ask. Good luck!
The GSR uses the exact same clutch as the LS, so you wouldn't really be getting any sort of gain whatsoever. The 99-00 civic si has a stronger clutch, but i think it takes a little bit of work to get it on there.
