Power Steering No Work
Old Feb 8, 2003 | 08:33 AM
LudeRage's Avatar
LudeRage
Default Power Steering No Work
Hey everyone. My 90 GS is in excellent condition, inside and out. One big problem however is the power steering. I checked the fluid and it is full. I also know that for Hondas you need Honda PS fluid or it won't work. Is perhaps the only problem that the guy before me put regular PS fluid in...or does anyone else have this problem?
Thanks,
Mike
Old Feb 9, 2003 | 07:20 AM
Gee3's Avatar
Gee3
Replace the pump. It probably went out. Not unusual on an older car. Good luck!
Old Feb 9, 2003 | 11:03 AM
pomansouth's Avatar
pomansouth
:stupid: same thing happened to my g2 and i just replaced the pump. forgot how much it was but its wasnt that bad i dont think. gl with the fix.
Old Feb 9, 2003 | 11:14 AM
jeff's Avatar
jeff
check the belts, or you could have a loose hose, all the fluid leaked and it doesnt work. good luck
Old Feb 9, 2003 | 07:11 PM
h0ckeyplr's Avatar
h0ckeyplr
check the belt first.
i have a service manual but it is for the g3, so i dont know if the same things would apply.
if it does and you want me to type up the first few steps let me know
Old Feb 10, 2003 | 12:43 PM
LudeRage's Avatar
LudeRage
hey thanks. hockeyplr, could you type up the steps for checking the belt for me? I'd appreciate it! (I'm pretty sure it should be about the same for a 90 as a 93)...
Hey pomansouth, do you have any idea of how much install was? I found that the p/s pump on this acura parts website was 160 bucks....
Old Feb 10, 2003 | 02:15 PM
h0ckeyplr's Avatar
h0ckeyplr
not 93, g3 as in generation 3 integra.
What is wrong with the steering, is it:
1. excessively light at high speeds
2. shock or vibration when wheel is turned to full lock
3. wheel will not return smoothly
4. uneven or rough steering
5. steering kicks back during wide turns
6. hard steering
Old Feb 10, 2003 | 06:31 PM
LudeRage's Avatar
LudeRage
well the power steering just doesnt work at all, ever...which makes it so the wheel doesnt return plus the fact you have to turn it over twice to make a turn
Old Feb 11, 2003 | 08:10 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Sounds like your pump is shot. It's a pretty common failure unfortunately.
Old Feb 11, 2003 | 01:27 PM
LudeRage's Avatar
LudeRage
Alright. thanks guys!
