Camber Kits
Old Jan 29, 2003 | 04:40 PM
BlackGSR's Avatar
BlackGSR
Default Camber Kits
What kind of camber kit are you guys using with the ground control coilovers? It looks like all GC sells is universal kits. Thanks for any info
Old Jan 29, 2003 | 05:45 PM
Mintegra97's Avatar
Mintegra97
i have the ground controol coilovers with totiko blues and the ignalls camber kit. Its a good camber kit and easy to install. but a tip would be when you take off the front stock thing that the camber kit replaces just cut it off with some heavy duty cuters or something cus i couldnt figure out how to take it off, but you won't want it anyway. Also another tip would be to lubricate the bushings on the camber kit before you install it with some water proof grease or lubricant because the urithane bushings squeek sometimes. Other than the squeeking that can be fixed the camber kit is great.
Old Jan 29, 2003 | 06:15 PM
BlackGSR's Avatar
BlackGSR
Thanks i think i will try them. Did you have to do the rear too?
Old Jan 30, 2003 | 07:39 AM
Mintegra97's Avatar
Mintegra97
yeah i got the ingalls kit for front and rear. the rear is pretty easy to install too. oh another piece of advise. try to put the kit on near by an allignment shop becasue you will have to drive verry slow up there to get it alligned right after you put it on becasue your camber will be so messed up. If you have questions on how to put it on just email me.
Old Jan 30, 2003 | 08:57 AM
b00gers's Avatar
b00gers
i have the ingalls with rubber bushings. yes they are easy to install. but be sure to grease them up. mines are squeaking like crazy.
if you can afford it, get the skunk 2 kit that replaces the whole arm.
Old Jan 30, 2003 | 10:13 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
skunk2 is money
Old Jan 31, 2003 | 09:13 PM
Taiwanze7's Avatar
Taiwanze7
skunk2 are the better kit. since they don't push the upper control arm outwards, pple have had problems w/ the ingalls kit
Old Feb 1, 2003 | 02:38 PM
pomansouth's Avatar
pomansouth
sorry to intrude the post but what do yall think about the progress camber kit is it any good and what kinda luck have people had with them.
Old Feb 1, 2003 | 03:15 PM
kfar09's Avatar
kfar09
i have the skunk2 kit and love it. no problems at all
Old Feb 2, 2003 | 04:03 AM
Diabolik's Avatar
Diabolik
Has an M3 now...
Does Skunk2 make one for the front and rear, or just the front? If just the front, what do you guys use for the rear?
-Diabolik
